Can someone recommend a good portable air compressor to keep in the jeep?
You would need a 5000 watt inverter. They go for around $500.will a 110 volt compressor work with a converter lot cheaper
thanks that is what i need to knowYou would need a 5000 watt inverter. They go for around $500.
Which is cheaper now?
Why wouldn't you use the stock power inverter that comes with the JK sahara and rubicon? I ask because I ordered the backcountry edition that comes standard with also and am looking for a portable pump option as well.You would need a 5000 watt inverter. They go for around $500.
It's a 150W power inverter and will run a laptop or phone charger at most.Why wouldn't you use the stock power inverter that comes with the JK sahara and rubicon? I ask because I ordered the backcountry edition that comes standard with also and am looking for a portable pump option as well.
Absolutely, it's what I used always. I have a ViAir 400 compressor that I throw in back all the time in case I run out of compressed CO2 or the valve doesn't work or something. But I've been airing up for about a half-year I guess with CO2 and haven't run out of it yet. Haven't counted but probably 28 stockish-sized tires. It is a lot quicker and easier than the compressor. But that said, the ViAir 400/450 is a great little portable if you want to go that route.I'm also looking to get a compressor, but what about those co2 bottle used for soda carbonation? I can get one "free" from work.
