I recently purchased a TJ and I'm going over everything and replacing everything that needs to be replaced. I've checked my Chilton Service Manual as well as the owners manual as stated on the cover of the PDC, but I haven't had luck finding what fuse F11 is for.
See the picture below:
No it doesn't, I'm gonna get the fuse from Auto Zone and see if that fixes the heater issue.
Thanks
Mostly old school..!
Slater 451 is right. Fuse 11 (40 amp in the PDC) is the hot lead through the relay to the blower motor. Fuse 8 (10 amp in the fuse block behind the glove box) is the circuit that energizes that relay, so if your blower motor isn't working, also check that one.
Thanks guys, there was actually a few things that I had to replace today.
That fuse, as well as the Blower Motor Resistor, and another fuse that was blow in the fuse box behind the glove box (for the cigarette lighter). Now everything is working well.
So thanks for the heads up. On to the next project.. o2 sensor. :)
