this past weekend, i was having slight loss of power steering on my jku. in a parking lot, i was having a difficult time turning while backing up. i checked the fluid and it was a touch low, but also smelled quite burnt. im thinking i need a power steering cooler for my jku, so was wondering if a transmission cooler from the junkyard would work for that? there are some 6 pass trans/ps coolers on ebay for about $35, but i could likely snag one from a junkyard for a bit less.
i still have stock steering on 37's (soon to be 40's) and lockers front and rear.
anyone run an inexpensive power steering cooler, and did it make a difference?
PSC offers a kit. If you go used make sure you flush it out well.
A new cooler is cheap, and better than one from a yard with who knows what inside, IMHO.
You're asking a lot of a stock pump to steer 40s with the associated low backspace and poor scrub radius, though. Might be time to weld a ram to that axle.
Mark
Sent from my SM-G935V using Tapatalk
going to use the 4.5" backspace wheels i already have because my one tons are 5.5" wider than stock as is. it also has 1/4" bracketry, so i can bolt a ram to the stabilizer mount. i just need to get one and port my box for it sometime.
Nice!! I set my 4Runner up the same way, though on full width axles, not tons. (Custom housings with Toyota-derived running gear). With 16.5" wide 39.5" Pitbulls at <4psi, I still couldn't turn them, and got tired of burning up pumps trying. A PSC pump and ram solved that problem completely, and the 4.5" BS wheels do take some of the stress off the steering components.
Mark
PS fluid gets hot quick under the load of turning 37's.
You need the flow, not sure a trans cooler will give you enough flow. I run the PSC cooler and it works like a champ.
