I had the power steering pump replaced in my 91 Wrangler and it started making a really loud noise and a major vibration. Could it be a bad power steering pump, steering box, hoses or something the mechanic did?
was the pump bled of air after installation???...you have to leave the top of the resevoir and turn the wheel back and forth all the way several times to get all the air out of the system...
Yes, the power steering system was bled. It was quiet for a little while. Then, all of a sudden it started making this really loud noise and you can feel a vibration in the steering wheel when I turn the wheels with the vehicle at a stop.
Well, I took the drive belt off, turned the power steering pump pulley and found it was binding. I replaced the pump and it works fine. Thanks for your help everybody.
