Hey guys so for some reason on my way to work this morning i noticed that annoying squealing noise when your out of power steering fluid well I was. So from what it looks like the fluid came from one of the lines. Has anyone else had this problem? How did you go about fixing it? How much did it cost you? Also looks like the only time i piss fluid is when i go to a full turn.
Most likely from your high pressure hose by the sounds of it. Make sure you can find the leak. Sometimes its as easy.as a bad o ring on the reservoir
my power steering pump exploded, and covered the engine bay in fluid. but it was new, so im guessing it was a factory issue, and was covered under warranty. it happened after I was adjusting some lift components, and moving the steering wheel from full crank to full crank
MARGARET, 10-14-51\6-1-12
my PS shaft broke. for no reason at all.
