I'm about to change my power steering pump and was wondering if anyone could give me tips or tell me what to do
It's pretty easy like with anything just look it over before you begin and take your time. No real tricks to it. Just make sure you have a bucket underneath or you will make a huge mess. Good luck
Knows a couple things...
Yep, sit a bucket under the steering box & disconnect the fittings so it drains. The key thing you must do after refilling the reservoir is to NOT start the engine until you have bled all of the air out of the lines. The new power steering pump will lkely be ruined if it runs before you have bled all of the air out.
The good thing is that it is easy to bleed all of the air out of the power steering system. Jack the front-end up so the weight is off the front tires. Then fill the reservoir with fresh brake fluid. Next, turn the steering wheel fully left/right 25-30 times. Keep the reservoir level up as it drops while the brake fluid circulates. Caution that the brake fluid level will rise & fall as you turn the steering wheel back & forth so if it's too full, it can overflow and freak you out by making you think it's leaking.
So once you have fully cycled the steering left/right (all the way to the steering stop limits) 25-30 times, then you can start the engine. Cycle the steering some more to finish bleeding it. It may still squeal a little until you drive it but so long as you cycled the steering enough before starting the engine, it'll be fine. Once you stop the engine, check the brake fluid again and top it off if it's down a tad. And make sure to wipe the brake reservoir cap area off so it is clean before removing the cap... you don't want any debris to drop down inside the reservoir.
Good luck... remember to not start the engine until you have bled the air out. :)
