I thought I burned up my power steering pump this weekend so I replaced it and did the on jack stands bleed but now it’s acting up still and sometimes acting like I don’t have power steering still and still making some noise, could it be as simple as doing a vacuum bleed or am I completely lost and it be something different like the steering box? Please help!!
If it's still noisy then you still have air. Lift the front wheels off the ground and crank hard left/right until the noise stop. Sometimes it takes 5 minutes.... sometimes an hour....
An hour running or off while turning the wheel? I did both for about 15 turns each but now I’m worried there is trash in the lines from when the old one went bad
Could you have bent something causing the steering to be stiff in a certain spot? Maybe the steering stabilizer? Were you wheeling beforehand?
