this might already be on here somewhere but i couldnt find it.
I have a tj with an I6 with a power steering pump that is leaking from the top of the pump:mad :. i have replaced a gasket on the bottom on the pitman arm shaft of a pump already. is it pretty much the same set up for the top is there a gasket that can be replaced or is it not as easy. im sure i have to remove the pump to do anything to it.
do you have any input on what or how to do this?
FYI, Pitman arm is connected to the power steering box and not the pump! if leaking on top of the box then I would check the fluid lines from said pump mounted on engine. good luck.
o yeah my bad i ment the box is leaking from the top were the steering shaft enters the box
