1 - 18 of 18 Posts
Does anyone have any experience with power windows? I have been looking at them for my full doors. I get sick of my left leg riding on the hand crank after while. I do like to use my half doors a lot, and was wondering if I could make a quick disconnect for them when I do indeed want to ride doorless or slap on my half doors.
Are they worth the price? And are they easy to install?
~Lev
I don't see why you couldn't just use some sort of wiring plug that you could disconnect anytime you wanted. I would put it just inside the door by the strap so you can unplug it easily. I have been thinking about the windows as well. Let us know how you proceed.
Yea, thats what I was thinking. I'll post pics once I decide if I wana do it or not. Just not sure if I think 200+ is worth it for powers windows.
~Lev
~Lev
My buddy has them in his YJ, He used the same kind of contact as what us YJ (and maybe TJ's) have to connect their third brake light, He can only use them when the doors are shut. The window motors are out of a 92 accord I do believe.
ive also thought about power windows.. im gonna redo the inside of my jeep this year.. i work laying rubber roofing and i have a perfect rubber to waterproof under my carpet and add more insulation for the winter.. im adding alot more electronics to the inside of my jeep like a sub in the center console..
but has anyone seen power seat brackets they can buy to replace their stock brackets?
I don't think I would want to waterproof under my carpet. If water gets under your carpet you will want it to drain out through a drain plug, not sit on a rubber layer. I would be afraid some would get trapped between the rubber layer and the tub floor and you would be really bad off!!
there are all replacement parts available for these things.
Its not that I needed replacement parts it was just difficult to fix it all together cause the window kept on falling of the track. And it took for ever to just get it to stop doing that. We actually ended up replacing the braket that holds the motor and had to drill a diffrent place for the joint.
But I would say its worth it all its really nice having power windows on a jeep!
1 - 18 of 18 Posts
