I have an AMC 360 that I recently fuel injected with 34" tires. I currently have 3.07 gears and I'm planning on installing a Ford 8.8 I'm thinking about going with 4.10 gears. Any thoughts or suggestions would be appreciated.
Thanks in advance.
Tim
Manual or automatic? What transmission you have will make a HUGE difference. IMO 4:10's is a good choice because is fairly low, and its the lowest you can find in a factory 8.8 (and D30's) which saves $
I have a 5 speed manual. That's kinda what I thought. It's the highest ratio without spending a lot of money. Would you consider going any lower?
It should be great.
Depends do you do a lot of freeway? In 5th gear 34's w/4:10s is probably just about right at 65. If its a trailer queen I would go lower if you can spend the money.
Keep it in 4-low and you will probably be happy with 4:10's off road
