Just swapped out my Pro Comp ES3000s on my 99 TJ with a 2.5" lift for Rancho RS9000XLs. The PO had installed the Pro Comps shortly before I purchased (they are in good condition so I believe him) and have less than 3000 miles on them.
Selling the full set of 4 shocks for $100 local pick up in the Northern VA area (you will have to come to me) or $100 plus shipping costs (which will probably run around $30 +/- $10.
These are designed for trucks/Jeeps with a 2" - 2.5" lift.
Nothing is wrong these shocks at all, I just was looking for a softer ride so my girlfriend would ride in the Jeep with me :facepalm:. Very easy to install yourself.
Post here or PM me if you're interested.
BTW these retail new anywhere from $38 to $48 a shock.
Pro Comp ES3000 Series
The twin tube cellular gas design of the ES3000 is engineered to substantially improve driving comfort and performance both on and off the road. With its 10 stage velocity sensitive valving, the ES3000 self adjusts to various road conditions while improving your vehicle’s handling characteristics. The large 5/8” chrome hardened piston rod and unique Teflon rebound stop delivers a comfortable highway ride and the ability to handle the most demanding driving conditions. With double welded shock mounts for maximum strength and the exclusive Pro Comp Suspension limited lifetime warranty, the ES3000 will ensure ultimate performance for as long as you own your vehicle.
Pro Comp ES3000 Series - Shock Absorbers - Shock Absorbers & Shock Accessories - Lift Kits, Suspensions and Shocks - by 4 Wheel Parts
What size tires did you use with the Pro Comps?
Was the ride that rough with the Pro Comps?
31" tires.
The shocks are great for getting you out of the muck and for driving off-road - on the street the ride is very firm.
Forgot to mention, I am throwing in four (4) red shock boots from the Ranchos I bought. I didn't install them when I put the Ranchos on and they are yours with the shocks. A $10-$20 value.
Bump.
Bump.
Sold!!!
