Ok so went mudding got a little bit of grass stuck in the back axil drive shaft and when I got home I started pulling the grass out and with it came axil fluid... What have I done to my baby? Lol
Administrator
What location is the fluid coming out of? The driveshaft it self, or the diff at the yoke?
Administrator
sounds like a bad pinion gasket..clean it up real good check the fluid level in the diff. Not a major worry, but something you should have fixed. I ran with a bad one for about a year.
Knows a couple things...
The pinion shaft seal that is causing the leak is actually pretty easily and inexpensively replaced. One 1 1/8" pinion nut holds the yoke in place that is on top of the pinion shaft seal. Remove the yoke that holds the driveshaft (after unbolting the rear end of the driveshaft) and the pinion seal is underneath. The pinion seal is pried/cut/peeled out and a new one is tapped into place. A 4x4 shop can replace it pretty inexpensively if you're not handy with such things. A seal is only $12-14 and it can be replaced in under an hour. :)
Discussion Starter #7
Sweet! Thanks guys I just needed an idea of what it could be and you gave me the whole problem and how to fix it. Appreciate it!
