1 - 13 of 13 Posts
Other than taking it to a shop and having someone do, what is the proper way to adjust the headlights? I have seen several different ways to do this. Is there any "technical specs" that should be followed?
Retired Moderator
If your lights are adjusted when the jeep is stock, then you lift it, wouldn't the lights be pointed too far forward? Mine seem kinda dim on the road but shining on the garage door, they seem bright enough. I also get flashed by people thinking I've got my high beams on.
Anyway, I figured my lights need to be adjusted.
This is out of a 98TJ fsm. It is more exact than the google thing. I hope it is useable on your year.
[url="http://www.vintagemusicprojects.com/jeep/servicemanuals/TJ98/etj_8l.pdf]Headlight Adjustment[/url]
Retired Moderator
Your jeep has a bad boob job Amy ;)
1 - 13 of 13 Posts
