If you look at the side of the door where the latch is, there is a round access hole that is right in line with a screw on the latch. The screw is called a "latch adjustment screw", but I can't find any info on it's purpose. Anyone know?
I could be wrong but I believe you can use it to adjust the latch in or out to tighten or loosen your door. If you are having trouble closing the door all the way you can loosen it or adjust it out a bit or if if it's too loose you can adjust it in a bit
Sent from my moto z4 using Tapatalk
