Welcome to the forum.
You won't need a bracket for the front just the track bar. The rear depends on if the lift you installed had one.
Also post your alignment numbers, specifically caster. What did your lift use to address the change in caster?
Let us know hat lift you installed. There's a big difference between a $400 Rough Country lift and a $4,000 Metalcloak lift.
