recently replaced the iac, cleaned throttle body and replaced grommets on valve cover. rubicon is a 2006 with 79k miles.
on passenger side around 1500-2000 rpm there's a puttering sound more visible in the first video below.
is this normal? vacuum leak? exhaust?
anyone that can help its greatly appreciated
video 1
video 2
Which video are you referring to
I don’t know maybe I’m losing my mind in the tan form passenger side engine bay sounds like a vacuum or exhaust leak but not sure how could be coming from passenger side
I just couldn't hear anything out of the ordinary in either video. Was wondering exactly what time you hear the noise in the videos - might help us hear it. Is there a check engine light? Does the air work properly? My wife's TJ has a vacuum leak somewhere which causes the Jeep to only blow air out of the defrost vents (ie, the vent selector doesn't work).
I don't hear anything unusual. The A/C clutch kicking in, but other than that... I don't hear anything strange. Looks like that motor is practically brand new!
Yeah I was gonna say that's the cleanest TJ engine bay I've ever seen.
Discussion Starter #7
Does the below help?
video 3
Around 0:03 mark? It's impossible to film but from inside cab and when giving it throttle it sounds like a steam train is best way I can describe it. Only thing I can think of is when I have time and things settle shop checking for exhaust leak somewhere but not sure why would hear it on passenger side if that were the case.
Thanks re: cleanliness. It's an 06 I picked up from New Mexico and had shipped to northeast a few weeks ago. 1 owner with 67K miles - sat in a garage most of i's life. Not a spec of rust and frame still has markings from the factory which is why I picked it up. 4th (and hopefully last) TJ.
4433688
4433689
4433690
