You're only going to add about 1/2" of lift in the front so you shouldn't need any additional parts.
Retired Moderator
Got a set of jku springs (17 & 58) I'm replacing my coils (15 & 55) on my JK anything I need? Shocks, brake line relocate?? Alignment?
As above, not enough change to require additional parts.
You might consider a 1" Teraflex puck up front to level it out. That would be 1-1/2" up front and 3/4" in back. That would be a great look for $32 and still not need anything else.
Teraflex 1 in. Wrangler Front Spacer-Individual 1953075 (07-15 Wrangler JK) - Free Shipping
They have a 1/2" version too if it sounds like more than you are looking for.
Vendor
This is a great idea! Some small Coil Spring Spacers will give you a small boost and should look great! If you're adding a bunch of weight you'd want to go with springs that have a higher rate, but for leveling or general stance/looks a spacer is a good, inexpensive option.
-Ryan
