I was looking at the Zone 1.25". Trying to make room for my UC fab tummy tuck. Is zone of decent quality or is there a better kit?
yesI have the JKS. Good and easy to install. The spacers are big. Are you installing a motor lift as well?
I have the 1.25" from RC.... took me an hour to install it ( no rust to deal with for me )
I hope you have done your research on TT's...... They are not cheap to do it right.....
It also depends on what you already have as far as lift size and the components that you installed already.
The Zone kit also reuses them.f9k9 said:I'm going to have to throw another kit into the fray here. I was running a PA 1" BL but, needed an extra 1/4" to make things easier with the install of my Savvy Under Armor. I already researched that frame flex had been the cause of one radiator failure for me and had caused many other rad failures when the oem grill snubbers or supports were replaced with other types. The Savvy 1 1/4" BL reuses the OEM snubbers.
That's my 2¢. Obviously many have had no issues with rad failures associated with other BL kits. I just wanted to remove one more possible ingredient to failure.
