1 - 11 of 11 Posts
My JKU is an overlander. WHich means sometimes I go long distances on highways. It also means it's heavy. The bumpers, winch, rack, and tent, plus camping gear are adding 500-700lbs.
I have not installed a lift kit yet, though I'd like to at some point, because getting some extra clearance would be nice. However, a lift kit while I"m carting my roof top tent is not a good combination on the highway. Too top-heavy.
I've seen a couple articles on using airbags / adjustable lifts, but haven't heard much feedback from Jeepsters on them. Is this something that I should look at? I'd sure like to have my suspension settled down for a couple hours on the highway, then be able to add more suspension travel when I'm finally on teh trail.
THoughts?
If you don’t go too tall, I’d think the top-heavy thing won’t be any real issue, at least not more-so than it is now.
Interesting idea. I had a Continental with rear air springs so this does intrigue me. I think that they wouldn't be good for off roading though. I'm not sure they would be good for a lot of down travel like a coil spring and if you had failure you wouldn't have any support at all.
I'm definitely feeling hte extra weight / high weight already. I'm iust worried if I put in another 1.5" of lift (i'm not a big lift nut... i just like the extra clearance and the slightly more aggressive look) ... i worry it'll get unmanageably wobbly.
I put airbags inside the rear coils of my street/strip car to have a more comfortable ride on the road but to stiffen them up and reduce the rear squat while launching on the track. Worked great!!
I ran the air lines to the license plate and used the valves caps to hold the license plate on.
I think they would work fine for your setup. It's a relatively inexpensive experiment.
I'll see if I have a photo and update.
I use airlift 1000 in coil air bags for the same reason.
when loaded I run 25 psi on the bags. That eliminates sag and firms up the ride. I also have ranch 9000 adjustable shocks. I put them on 8 when loaded.
During the summer I run topless. Drop psi to 5 and shocks to 2. Rides like a champ. Love the air bags.
I paid less then 100 bucks off Amazon.
I'm running airlift 1000s on my JK pickup.
The worked great except a few little things.
1) rocks would get into the upper coil buckets and caused the spacer above the bag to sit crooked and split. I sent a message to airlift in July and never got a response
2) I had my first major leak recently. I was airing up to haul a pretty decent load and some let loose, haven't crawled under it yet.
I ran 5-8psi empty and 25-30 loaded with fox 2.0 ipf shocks. Truck empty is 5300 (2800 on the rear) and loaded I have been in the high 6k range (not proud, but it happens)
Just got under to take a look. The spacers that were cracked are both gone and the nipple is off the right bag.
picture from today and July 4th
1 - 11 of 11 Posts
