Got my 1988 YJ with 6/94 hard doors they don't fit right maybe from a TJ not sure, the right side does'nt even open either from the inside or out and when it does it drops down about a 1/4". Any help with this would be great Thanks.:banghead:
Sounds like you need to adjust the hinges on the outside.
Founder, ThumbJeeps
ditto... loosen the hinges without stripping the torx bits then allign the door for your jeep, then crank 'em back tight while the door is shut with an even gap all the way around it. It you need to, you can use shims of cardboard to get them alligned right then just slide them out when done.
