Hello. I purchased a set of JWS fog lights and am told you have to splice wires to install them. I have no idea how to do that. Is there like a adapter or something you can use to avoid cutting wires and make it so you just plug in.
Formerly Tombstone17
You can pick up the adapter on Amazon, but yes you have to cut the stock plug if you use the one you get with JW's fogs. I had a problem with the adjusters on mine and swapped the holder and adjuster from the stock fog lights ( they pop out of the holders and snap in)and used the stock adjusters. I cut he stock plug off and soldered the leads and installed the plastic wire wrap to protect the wires from the mud slinging...
