Installed this harness on my 13 wrangler for towing behind my MH. Hitched it up and test-towed it yesterday without issue thanks to all the info gleaned from those here who shared their experiences.
My question is does this harness make provision to put any charge back in the Jeep battery? I think it does not but am not sure. Thanks
would be simple to check with a volt meter just hook it up to your motorhome and start the motorhome up and check the voltage at your jeeps battery.
You can charge a battery through the cigarette lighter if you want... if your MH is putting out 14.4 to the Jeep wiring, it's going to provide some charge to the battery. Not many amps through those little wires, but it will be the same as a trickle charger.
