The new 5 speed automatics are what is called a learning transmission. It adjusts the shift points to your driving style. But it will take several miles of driving for the re-learning process.
But first, remove both you positive and negative battery cables. Then hold the ends together for about 30 seconds, now re-install. Your trans will now be back into the learning mode.
It may take a while, but it should re-program the shifting points on it's own!!!!!!!
