I bought a used '99 TJ a few years ago. I was told it had a 3" lift, but not what kind of lift it was. It looks like it has a budget boost lift on it, I'm guessing it's just a 2" lift since I have not seen any 3" BB. I had a 3" body lift installed about a year after I purchased the Jeep. Do I need a SYE and CV driveshaft? It has a 4.0 liter engine. 35" tires.
Depends. If you installed a MML and still have vibes then it'd be a good option. Or if you dropped the tcase and excavate all the terrain you run then a SYE/DC shaft would give you inches of clearance and give your rig a cleaner look.
oh and inb4don'tdobigbodylifts
Yikes...a 2 inch budget boost and 3 inch BL? If that is correct I would say no need for SYE.
Can you snap some pics of your BB, suspension, your rear drive shaft, and the back of your t-case? Why do you think you need one now after 3 years?
Didn't really do any research before putting the body lift on. After reading on here, I am regretting the body lift
