Question about tire size!?help
1811 Views 18 Replies 8 Participants Last post by  brandon-99tj
Ok so im looking to get tires without lifting. I am wondering for a 2001 wrangler what size i would be safe with no lift. I have a buddy who has a tj and he didnt lift it he now cant steer all the way to the left or right because the tires hit the wheel wells.
1 - 19 of 19 Posts
Rubbing is an issue for any over size tires, currently I am running 33x12.5 good year mt/r's with only a 1.25" bl, rubbing will always be an issue
Ive read that you could fit 31s without a lift and stock flares anything bigger you would need wheel spacers but if you had flat flares you could fit 32s and spacers
I have 31" duratracs on my stock height tj. I got them in preperation for a 2ish inch lift. They only rub the sway bar at full turn so i put one washer behind the steering stops to solve this. I wouldnt do much serious offroading as they will rub fenders hence the soon coming lift.
I'll post a pic when i get off work
Ok cool thanks lot guys yea if u could post a pic tht wud be great
31x10.50 is as big as can be installed on an unlifted stock TJ without rubbing. :)
Perfect thankyou for confirming. I am at a tire place now and right before you posted that they went up stairs to get me that exact size.
What tires are you getting? And pics or it didnt happen.... :)
i put em on ill put a picture in a minute
Looks great! Congratz on the new shoes. I be jelly.
Thanks. What u did to ur hood looks sweet btw.
Hey thanks bro. Not near as cool as your new tires though.
No it won't. It depends on the rim back spacing. I have 33x12.5. They don't rub on anything.
Oh well I have 1.5" spacers on all 4 rim set ups and I run constantly...maybe I just don't understand what we are talking about haha
Hey man my 31s are rubbing right now if i get 1.5 spacers you think that will stop the rubbing
You guys could always just buy a small and cheap economy lift. 2"s can make a big difference!! No pun intended lol
That would work if you dont mind spending the money, but if you're cheap like me you could just adjust your steering stops with a washer or two. And its alot easier than takin all the tires off and putting them back on :)
1 - 19 of 19 Posts
