1 - 20 of 46 Posts
Ok so I have a 1998 Wrangler with the 2.5l. I have stock Grizzly wheels and 31x10.50 tires. They rub a little bit on the frame when I make a sharp turn. I was wondering, if I got a new set of wheels with different backspacing would that cure the rubbing issue? If so, what backspacing would I need?
Also my Jeep is white so I'm thinking of black wheels....Opinions?
Administrator
I would go with a 15x8 rim with 3.75 back spacing. This will also allow you to run a 12.50 wide tire down the road if you want.
Ok awesome. With 3.75 back spacing the tire will be stuck out farther. Correct?
Knows a couple things...
It takes two five cent washers and ten minutes to fix that. Go to Jeep Steer Stop Adjustment
Wheel backspacing is the distance between the rear-most edge of the wheel and the wheel's mounting surface. The yellow tape measure in the below photo is measuring how much backspacing the wheel has. The more backspacing a wheel has, the further into the wheel well the wheel is positioned.
Thanks!! I'll do that soon (and probably still get new wheels:punk:)
You won't need those washers with new aftermarket wheels. :)
Yea but that'll let me wait till summer at least to keep the salt off of them for one winter.
Discussion Starter · #11 ·
Im thinking of these wheels. 15x8 with 3.5 back spacing....what do ya think
Your wheels will stick out unnecessarily far with only 3.5" of BS. The minimum I'd run is 3.75" with 4" being even better.
I have them with 33 12.50 15 DuraTracs Rating C and they fit OK. I wish they were 3.75 or 4.0 BS instead of 3.5 BS, but they are fine !! Pricing on this wheel has been substantially lowered since Ion came out with new designs..........tough to beat.
So, is the above photo "Ion Alloy 174 Black Beadlock Wheel (15x8"/5x114.3mm)" is that you have? Is that the correct size for a TJ (5 x 4.5") I find them on Amazon for only $110 and that includes shipping. I see it is only a 3.5" backspacing - but a 1" spacer would resolve that.
Adding a 1" spacer would give that wheel with 3.5" of backspacing the equivilent of 2.5" of backspacing. A spacer positions the wheel further out of the wheel well, not further in. :)
Discussion Starter · #16 ·
Would 4 inch back spacing be enough to not rub. Because I would rather them not stick out as much as possible if that makes sense.
4" of backspacing would be fine, anything between that and 5" would work fine for your 31x10.50 tires.
Discussion Starter · #18 ·
Nice jeep man. Those wheels look really good. I might just pull the trigger. They're only like 89.99 a piece from quadratec.
Discussion Starter · #19 ·
Thanks. You've been a great help. I'll look around and see what I can find and update you guys.
helmsy,
you can get free shipping by going to google and type in "174-5865B quadtratec", then click on the "shopping" option, then click the link that pops up and you will see free shipping when you add it to your cart......
1 - 20 of 46 Posts
