1 - 20 of 22 Posts
I just test drove a 2016 Wrangler 2 door Sport 6 speed manual the other night. My question has to do with my foot when shifting. Whenever I shifted, my left foot would hit the OBDII port since it is located right above the clutch. This is not a deal breaker for me, but I'm just curious if anybody else has experienced this issue (I did do a search but found nothing).
Thanks,
Rich
Easy fix, buy an auto and a M.O.R.E. dead pedal :bop:.
Drove manual transmission JKs for years but never had that issue.
Maybe the seat was adjusted too high up...?
I was wearing sneakers at the time, size 12. I got stuck in rush hour stop and go traffic, which is part of the reason why I think I noticed it. I didn't think of adjusting the seat, but I will try that the next time.
As mentioned lower the seat as low as it goes.
Other possibility is that you are 7 feet tall.
The first two days I owned mine I had the same problem. Now after a couple weeks it has not happened again. It's a rather confined space but somehow muscle memory plays a role in resolving.
I had the same issue when I got mine and found it rather annoying. I didn't think there was any way they'd design it like that, with something I'd catch my foot on every time I released the pedal!
I got in there and looked around and there was a great big wiring bundle of some sort that was jutting out above the pedal. That's what I was hitting. I shoved it over to the left and got it to stay there and never had an issue again. :)
+1, wife and I both had the issue while test driving. Getting the seat position right and muscle memory solved it.
Discussion Starter · #15 ·
I'm 6'2", but it was likely that I did not adjust the seat at all when I got in. The position of the seat seemed right, so I just started to drive. As the test drive continued, I tended not to hit it since I knew it was there. Not sure when I will test drive one next, but I will be sure to adjust the seat before I leave the parking lot.
Thanks for all the replies.
Rich
Thanks,
Rich
But the big question is, did you have fun? Pics when you take it home :)
Same here. If you notice on the passenger side, there's a sort of "holder" for this wiring. I couldn't find one on the driver's side, but it's possible it broke off or something (I bought my Jeep used).
I zip-tied that wiring to some other wiring that's attached to a ground to make sure it's all tucked close to the body. No issues since.
Rich
I've had my JK for six weeks now and still can't seem to get the seating position 100%. I'm coming from a TJ which I am starting to miss. Amazing how different the seating position can be on the two models.
Discussion Starter · #19 ·
I did enjoy every minute, but doing a test drive at night during rush hour traffic while raining was not the ideal time to test drive. However, when I got back to the dealership (they let me test drive by myself) and told them doing a test drive during rush hour in the rain was not ideal, they said come back on a Saturday when it was sunny and I could test drive it again topless!
In that case you may as well bring your wallet and pen as you will be hooked for sure.
1 - 20 of 22 Posts
