I have 1995 and want to replace the radio, but need to remove part of the dash first.
To remove the dash, the plastic heater control knobs have to come off first.
My manual doesn't explain how and I can't figure it out.
Thanks in-advance for your help.
You should be able to take the dash off without taking the control knobs off. Remove all the screws to the center dash gauge panel to access the radio.
The knobs are glued on, but don't need to be taken off for a stereo change. If you take out the screws that hold the center dash it will come off without the heqater control needing touched at all.
There are 3 screws that go up into the padded part of the dash, and 3 in under the "ledge" of the dash under the gauges. Then the plastic part of the dash can be removed.
