I have one all prepared and ready for install just need the mountstop weld on. Question is I have 3.55 gears in front and the 8.8 has 3.55 I just want to make sure that it will still work. Thanks in advance.
I have the i6 as of right now I have plenty of low end for what i do only running 31 inch will be 33 in future if all plans go right.denisbaldwin said:You should be fine with the 3.55s. That said, you're probably going to want to bump both up to 4.10 or 4.56 or 4.88 eventually to get a little more low end grunt.
Denis
OK cool... then you should be all set. I'm so used to the underpowered 2.5 that gears are typically the first thing I recommend.I have the i6 as of right now I have plenty of low end for what i do only running 31 inch will be 33 in future if all plans go right.
That makes sense.nick50471 said:The difference between the front and rear is because of the different ring gear sizes in differentials. The only time the front and rear are the same is when you have the same differential. For example D44 in both f/r or D60 in f/r.
That's not always true.nick50471 said:The difference between the front and rear is because of the different ring gear sizes in differentials. The only time the front and rear are the same is when you have the same differential. For example D44 in both f/r or D60 in f/r.
