1 - 12 of 12 Posts
fronts do I believe rears are slightly different.
ExtremeTerrain.com Sponsoring Vendor
X2
The fronts should bolt up but the rears won't. A good number of people will remove factory flares for aftermarket ones so you shouldn't have too much trouble finding a used set of factory flares if that's what you're after! Let me know if you have any questions!
-Ryan
X2 The fronts should bolt up but the rears won't. A good number of people will remove factory flares for aftermarket ones so you shouldn't have too much trouble finding a used set of factory flares if that's what you're after! Let me know if you have any questions! -Ryan
Actually the deal is I found a set of stock painted Anvil flares off of a JKU and I wanted to replace my plastic ones off my JK with the painted ones
JK 2dr and 4dr Unlimited fender flares are the same. There's no separate part # for an Unlimited.
1 - 12 of 12 Posts
