octane basically means the amt of heat and pressure it takes a fuel to ignite.. if your vehicle was designed to run the most efficient on 87 octane then thats what you should always run.. if you have a more high performance vehicle that can bure the higher octane efficiently then you put that in.. as for jeeps i wouldn't think any stock jeep would perform better on anything more than 87
