1 - 15 of 15 Posts
I did some searching and I am quiet confused...I would like to know how to find out if I have a lift and if so, how high of a lift I have on my Jeep. I have a 2008 Unlimited Sahara, which I purchased about a year ago, I believe that there is a lift on it as it seems to sit higher than other Jeeps when I am parked next to one. I would also like to know what size of tires I can fit under my baby...would like to get some different rims (perhaps Moto Metal MO956 or TIS 535V), 18" and some more aggressive tires. Any and all help would be greatly appreciated. Attached a few pics. :happyyes:
Vendor
I did some searching and I am quiet confused...I would like to know how to find out if I have a lift and if so, how high of a lift I have on my Jeep. I have a 2008 Unlimited Sarah, which I purchased about a year ago, I believe that there is a lift on it as it seems to sit higher than other Jeeps when I am parked next to one. I would also like to know what size of tires I can fit under my baby...would like to get some different rims (perhaps Moto Metal MO956 or TIS 535V), 18" and some more aggressive tires. Any and all help would be greatly appreciated. Attached a few pics. :happyyes:
It looks to me like you have maybe 2" or lift? 1.5"? Take a few shots of the coil springs. If you have spacers you can measure them to know exactly how much lift you have. If you don't, you can measure the springs versus stock specs (I forget what they are) and calculate lift from that.
It looks like you could fit 35's under it clearance wise. You want to make sure you get wheels with the proper backspacing for the size and width of the tires you want to get.
Let me know if you have questions!
-Ryan
Supporting Member
I agree. Looks like it is lifted. I too agree it doesn’t quite look like it is 2.5”. I see a red shock boot so probably Rancho shocks. I would venture to guess a spacer lift and some shocks.
As for the wheels and tires, just a heads up, tires for 18” wheels are a lot more expensive than tires for 17” wheels or smaller. You could probably get new tires and 16” wheels for the cost of new tires alone for 18’s. That being said if you have the budget and like the look go for what you want. Myself or Ryan can hook you up with a complete coil lift (if you wanted) and the wheels/tires of your choice.
Another thing to consider if you do go with 35” tires is gear ratio and spare tire carrier.
-Dan
Thanks for the replies thus far, I am at work and plan on giving her a scrub down and trying to check the lift again afterward. I tried measuring the coils, but got confused, so I will look at what Ryan said and give that a try. If anyone knows of any other way to measure the lift, that is "dummy proof", feel free to pipe in. As for the tires and rims, I want to keep the size that are on there, 18" and wrap some 33's around, with enough clearance not to rub and be fully functional to take her off road. :) I would go smaller rims, but don't want to have to do any alterations. Thanx again!
Retired Moderator
take this measurement on yours and subtract 18.5" from it and that is your approximate lift
Definitely check to see if you have coil spacers as it'll be the easiest to find out how much lift you have if you do. A JK can fit down to 16in rims with no issues, and some 15s depending on the brand. I can tell you right now the PO of mine had 18in alloys and when I got new tires I dropped down to new 17in rims, much much cheaper.
Ok, so I measured the top of the shock to the bottom on the front and it was about 23"...still a bit confused on how to get the correct measurement of the lift I have...ughhh......here are some more pics, let me know what I should do next, thanks all. :)
Looks like possibly a skyjacker shock by the color.
Retired Moderator
measure the bump stop on the lower front spring perch. looks like a 3" lift or so.
kind of looks like a Bilstien steering dampner shock.
Retired Moderator
based on your numbers I would say 2.5"
1 - 15 of 15 Posts
