Hey there!,
I was thinking of adding Teraflex 1" Front Coil Spacers to my 2015 Jeep Wrangler Unlimited to fix the front factory rake. I plan on keeping factory tires for a while, do I need to buy anything else or will just the two coil spacers be fine?
Spacers: https://www.quadratec.com/products/16190_1003.htm
Its nothing to worry about. Get the spacers in and look at the angle of the swaybar. If low (-10 +) you can look for new links. Using the rears in the front is a option too. Then you would buy longer rears.
Isn't it the fronts in the rear? I have the Teraflex 1.5" lvling kit and it came with new grease able front links. And I'm pretty sure I relocated the Fronts to the back.
