Im wanting to get the rubi express 3.5 ta 4" super flex lift for my 05 wrangler x with 6 cyl....im wonderin a couple things...1. If I do sye do I still have to lower transfer case... 2. How much does drive shafts cost and which is better...
Installation of an SYE will also require adjustable upper rear control arms. The t-case drop is not required with an SYE. CV shaft will cost around $250 shipped from Tatton's
1 get the super flex kit that comes with the adjustable uppers and look up lengths on this forum.
2 tattons and tom woods make great products, tattons tend to be cheaper from a cost perspective.
3 a sue will be required because a 3.5 lift will net around 4-4.5 " of lift.
4 go with the 3.5 lift, the springs have a higher spring rate than the 4.5 and don't sag in the front.
I have the 3.5 and its a great lift. And I recommend bilstien shocks.
