1 - 17 of 17 Posts
I'm needing to replace my sway bar quick disconnect endlinks (OEM ones) and I'm seeking any recommendations. Anybody have any experience with the RockKrawler set? I can't find much out there on them. JKS seems to be the most popular but if there are lesser known quality brands, please let me know.
JKS are worth the money.
Reactions: kraigc3 and Bobnh
Bella's Jeeper
I had JKS until I went to Antirock. They are great, except when you have a dozen or so people watching and then they are a PITA :)
Can't go wrong with JKS, yes they take a little longer to reconnect but are a fraction of what an Antirock costs.
OK, I'm a bit confused. There are JKS quick disconnects and "quicker" disconnects. If I want to use is it with my electronic disconnect, will either, neither or both of these work?
Thanks,
Thanks,
If you go with a JKS quicker disconnect or any other that style, you will no longer use your disconnect button - you'll disconnect manually
Thanks,
you can still use your electronic discos with jks or probably any others. I have used my electronic discos with both standard jks discos and jks flex connects.
Are all these popular quick disco's all rattle free? I cannot tolerate the sound of loose end links, I'm having a tough time imagining the pin keeping the link from rattling. My stockers will rattle if they aren['t torqued way down, I can't imagine how a pin does this rattle free. Please educate!
Mine loosened up and rattled where the stud mounted to the frame, but since I tightened it no issues, no rattle. The pins themeelves have bever been an issue, nor were they on my TJ. And I drive on a LOT of washboard and crappy roads.
Sent from my SM-T380 using Tapatalk
Grooving With A Pict
The Steinjager's are not, they rattle at low speed going over bumps but they're silent once you get over about 30 mph. It bugged me at first, but the design and ease of use outweighs the noise. And the price is a big selling point, along with the fact that they sell all of the individual components so you can replace a single part if you break something or wear it out.
JKS, never had an issue with them
Does anyone make quick release pins for the stock end? From reading the terafelx pins are too large in diameter for the stock ends?
1 - 17 of 17 Posts
