So I recently moved my 2m antenna to the front bumper, and am picking up tons of radiated noise with the engine off, ignition on. Any body solved this one already?
No. Getting RF with ign switch on, engine off.sparky said:Now we have a head scratcher. If I read you correctly, RF noise with everything shut down.
10-4 on the straps.Ibuildembig said:Fuel pump....also, the woven ground straps are the cause of most noise. I would use a stranded/coated copper lead instead. The R56 grounding manual outlines why the straps are not to be used. Hope this helps
