So in the mornings usually the radio works. Go to shop, 45 mins. no problem. Come out after work and usually nothing. Thing is it isn’t totally dead. Faint glow of the backlight and the radio cooling fan running. Turn off the ignition and open the door still the glow and the fan running. After 20min approx it will finally shut off. Usually won’t work the rest of the day. Next morning it works and the above starts all over again. Took out the h/drive so it only has am/fm and still the same thing. Any ideas as I don’t want to buy another. Too much money. Thks
following.....new to us 2015 JKU with U430 no nav.. Backed it out this morning radio worked, got in it 6 hrs later and no audio or display...crap . hooked scanner up no radio codes, all of a sudden audio came on but still no display.. unhooked (-) battery cable for 5-7 min and everything came back to life.. I've read to touch upper right area on display to reset but I've not tried it due to being P'd off..
