I want to replace the radio in my 98 tj. It has a aftermarket kenwood and I hate it. To complicated, 1 button does 50 things. I do need blutooth and would like didgital. Anything out there that doesnt require modifiying insert?
You probably have the same head unit that I do - it's awful from a usability standpoint.
Assuming it was installed properly, the head unit will have retaining clips you can bend to get the HU out of the mounting bracket.
Just order a single DIN HU from Crutchfield. It will come with a new mounting bracket and wiring harness for free. Will take about 5 minutes to install once you wire the harness.
I put this one in https://www.crutchfield.com/p_613KM318BT/Kenwood-KMR-M318BT.html?cc=01&archived=
I like it, easy to use, and the Bluetooth never loses connection. The range for the Bluetooth is kind of lacking , doesn't reach outside of the jeep, but anywhere inside the jeep it works perfect. Also it is Marine Rated, perfect if you enjoy doorless/topless life often.
Crutchfield is so legit. They will send everything needed to mount/wire it up. And they are super helpful if you have any questions. 100% would buy through them again.
I see there is a newer model available now, so I can't speak for that one.
Mine had pos in it when I got it, wiring all messed up and so forth. Tore it out and picked one of these up just to see since it was less than $20 and had bluetooth. Actually works good, bluetooth connects easily and stays connected no problem and I figured it someone wanted it worse than me have at it. It was $20. Also has USB port for ipod hook-up or phone charging. Threw some 5.5" & 6.5" Kicker speakers I had in garage and sounds pretty good, noo problem hearing it top off at highway speeds.
https://www.walmart.com/ip/Dual-Electronics-XDM16BT-High-Resolution-LCD-Single-DIN-Car-Stereo-with-Built-In-Bluetooth-USB-MP3-Player/54596679?findingMethod=wpa&requestUUID=8acbd4c5-71af-46f0-a90c-1ea4e4264f8b&tgtp=0&cmp=18292&relRank=3&tax=91083_3947_2573876_3877515&pt=bp&adgrp=19384&bt=1&plmt=1145x345_B-C-OG_TI_2-20_HL-BOTTOM&wpa_qs=gMD4glFufTGep6pE2gUdBOu3vkl83t3K_BDUPTrSe1aosBJFH0N8Y-pxw5KhlDKhBH2YULezMYM-NRyEiSeX2wXqIUaX9BwlufT4TDPe1_w&bkt=277&tn=WMT&mLoc=bottom&pgid=91083_3947_2573876_3877515&isSlr=false&itemId=54596679&relUUID=8acbd4c5-71af-46f0-a90c-1ea4e4264f8b&adUid=1847e603-a911-4f76-a5d1-614251907ccd&adpgm=wpa&pltfm=desktop
