and i seen a puddle of water on m passenger floor mat looks like it's coming from under the door and over the rocker? the good thing that's all i seen!
Join the crowd.... LOL I have had this same leak, looking closely while it poured down, I noticed a VERY FINE line of water running down the inside of the front door frame, and draining under the door sil and running onto the floor.
I stuck a small piece of weather stripping ( auto parts store ) on the door frame and this channeled the water to the outside.... It worked for me.
Here is a link that you may want to bookmark for later use....good luck ! "BH"
http://wkjeeps.com/misc/Wrangler/JK_Water_Leaks_All.pdf
I have been dreading the moment I see a puddle of water in my Jeep. I've had it for 1 month and so far after a couple moderate showers, still dry. We will see if it stays that way.
Join the crowd.... LOL I have had this same leak, looking closely while it poured down, I noticed a VERY FINE line of water running down the inside of the front door frame, and draining under the door sil and running onto the floor. I stuck a small piece of weather stripping ( auto parts store ) on the door frame and this channeled the water to the outside.... It worked for me. Here is a link that you may want to bookmark for later use....good luck ! "BH" http://wkjeeps.com/misc/Wrangler/JK_Water_Leaks_All.pdf
Thank you so much for posting that link. After reading through that manual I think I found some spots on my 2010 JKU that are missing some foam. I'm going to see if I can get that foam kit and fix 'er up.
Build Thread Queen
For what it's worth, guys, there is a link to download the Leak PDF in post 1 of the Soft Top HELP!!! thread, so it's easy to refer people to. :)
