Yes. They are mounted to a hole you drill in the tube, probably below the latch. Take the bump stop and with the door closed, see where it fits tightly between the tube door and the door frame. Then drill a hole. Screw it in. Be aware that the screw will compress the bump stop when you tighten it so don't worry of it seems too tight. It actually works well as you can tighten the screw to adjust how tight it is
