1 - 12 of 12 Posts
So this has been going on for a while now.
when shifting from first to second there is a rattling sound from under the center console, and again from second to third but not as noticeable.
mostly it happens when starting up a hill and is not present going down hill.
Any ideas of what this could be?
Have you checked fluid levels in your transfer case and transmission?
Supporting jeeper!
HarryJeepGuy said:
Transfer case shifter linkage.
Correct! It's the brass bearing/bushing attached to the body bracket that rattles. Mine is currently doing the same thing. I forget the part number from mopar but it's around $6 for the piece
Could be tranny mount if it sounds like your 4wd lever is buckling in the floor boards, is there vibration? There comin to fail, put a bar on your tranny and see if she wiggles. If it is it can take out your pas. side engine mount. go poly!
i recently had the same problem with a rattle at certian rpms and shifting, mine wound up being the cat was bad. the core was busted and rattling. easy to fix either cut behind cat about 2-3 inchs. grab long metal bar or long screwdriver and break up what is left of internals of cat and remove all that is loose. get a exhaust band clamp and reattach the cut exahust with exhaust band clamp. hope this helps...:popcorn:
1 - 12 of 12 Posts
