1 - 12 of 12 Posts
The joints are fully rebuidable and the other end is a rubber bushing. RC warrantys them for life.
Some say the joints don't hold up. I've never seen where they are actually failing. RC is always upgrading where deficiencies are found.
im gonna jump on the offer. bow the seller told me that bc the CA are adjustable that i can put 4" springs under it without and SYE for the time being?
Yep you sure can; as long as you drop the t-case about 1.5" that is. I'd be surprised if you could put 4" springs under any TJ without an SYE or t-case drop, adjustable arms or not.
When I first got RC's 4" Basic Kit. ($499) I ran it with the 1.5" t-case drop that comes with the kit and nothing else. It wasn't until last year when I added the Ford 8.8 that I needed adjustable arms to dial in the SYE and pinion.
Better hope you are getting a good deal... you can get Currie arms for not much more with real johnny joins at either end. I think they might even be double adjustable.
i need a set of upper control arms for the front of my jeep since i lifted it. any suggestions on what brand. i already have RC rear lower control arms. just seeing if any others are better for the front
There are plenty that are better if you want to spend the cash; Savvy, Rokmen, anything with JJs at both ends. It's all in what you want to do with your Jeep.
1 - 12 of 12 Posts
