Chipps are useless on NA engines unless you are making High revving NA machine (upwards of 8k rpm) If you got boost than thats another story but thats off topic.. replacing the chip with a "better one" is like those ram programs that are suppose to make computers faster..
I call BS. I have seen plenty of American, low revving, N/A cars and trucks benifit IMMENSILY from chips. Jeep 4.0L do not, probably because its such an old design. The new 4 cyl on the other hand, may be a different story. Sounds to me like you are re-iterating what a 16 year old told you in school
Chipping a car reprograms fuel/air ratios, timing, whatever the programmer decided was nesessary for a more efficient burn. by changing values in the computers programming.
If you want some power i'm preatty sure you can get some when replacing the camshaft gears also since then you can tune it to whatever you want.. you can make it higher hp with lower torque or vise versa..
If you want to go bigger turbo or supercharger is the next step.....
I have a degree in Automotive Technology (as well as some computer programming education
), have worked in Automotive Restoration shops, and dealerships etc. and that statement has me very confused. Maybe its because I just woke up or I am having a brain fart, but I have never heard of a "CAMSHAFT GEAR" other than for Timing or for a fuel pump or a distributer etc. Even those are more for older cars with the exception of the timing chain. Nine times out of ten those are built into the camshaft, making it impossible to simply "Swap gears," again with the exception of the timing gear. Simply replacing the timing gear isnt going to do anything. If you want to mess with the timing gear, just adjust the timing itself instead. Now, you can replace the shaft itself, and in turn decide what kind of lobe you want (lift, duration etc.) to create more torque or more HP or a balance etc. but that is no cheap or simply bolt on like a supercharger pulley.
As for the "next step" being to get a turbocharger or supercharger, its not really that easy. I am sure you are generalizing and did not mean that litterally, but for the sake of the un-informed noobs lurking around, there is much more to turning a NA motor to forced induction than just buying a blower or a turbo. In most cases the bottom end must be rebuilt stronger, the entire fuel system replaced, new computer programming, than the transmission/rear etc. if your gonna produce a decent amount of power. You "CAN" slap on a supercharger, say running 4 lbs, and not gernade your motor as soon as you start it, but 4 lbs aint really gonna be worth the cost and aggrivation either...Your talking, what about 25% power increase, so say 250lbs of torque instead of 200, for say $1500 bucks. Those number arent 100%, just a quick figure I did in my head to give you an idea.
Out of curiosity do jeeps run rich or lean? If they run lean you can get one of those ebay resistors for 5 bucks so it reads the intake air is cold there fore spray more fuel and get some power and worsen mpg lol
Jeeps have oxygen sensors, meaning the computer is constantly bouncing between lean and rich constantly, but is keeping the air fuel mixture right around 14.7:1 (stoichiometric). As for which side the computer likes to lean on, I am not 100% sure, but that is what a chip is going to do. A chip is going to (along with other things) adjust the air:fuel ratio for more power.
Now, I am not trying to rag on you bro, please dont get that impression, I am just trying to keep people from being mis-informed. If anything I said was incorrect, please enlighten me. I have no problem admitting I am wrong, but as far as I have been taught, the above statements are correct.
