1 - 14 of 14 Posts
I am going to 5.13s in my JK, i know i need a front carrier for the dana 30.
I am getting two stories for the dana 44 in the rear. One place i read says theres a "differential carrier break" between 3.73 and 3.92 and one the next place says NO. That said, i can't find any part numbers that differentiate between the two, If i do need one does anyone have Yukon part number?
Just throwing this out there. Putting 5.13s in a Dana 30 is a bad idea.
Sent from my SM-G955U using Tapatalk
Its pretty much a street/wife goes in the snow jeep does see the the forrest service trail once and awhile or a jaunt down the beach in the sand but not much more...i am not convinced that a 3.8 pushing an automatic is capable of hurting anything other than my pride. :)
The rear carrier break is between 3.21 and 3.73. So if you have 3.73 you are fine.
As for the front D30 I believe it is the same carrier break 3.21/3.73.
5.13 are just fine but do put a heavier front diff cover to support the housing center section.
Reference https://eastcoastgearsupply.com/i-11860188-dana-30-jk-carrier-3-73-up.html
Beware when researching that you specify JK D30 and JK D44 they are a different animal the then the previous versions on these axles.
Wow,
That's a lot of gear for a grocery getter.
just say'n
Wow,
just say'n
Like Bob has already said, 5.13 is the norm for a 3.8 auto.
For perspective, 5.13 w/3.8 auto is equivalent to 4.10 w/3.6 auto.
And people wonder why the 3.8 felt gutless. It was all in the gearing folks.
Really.
That 3.8 must be a gutless engine.
The 3.8L isn't all that bad but the 42RLE was a dog due to it's gearing.
It’s not when you gear it properly. 3.8 with 5.38 gears and 37s is just as snappy as my 3.6 with 4.10 on 35s.
An engine that needs 38's to be snappy is a dog.
Reminds me of my '47 CJ2A.
jmo.
jmo.
I think you are missing my point. It’s not the engine, it’s the shitty 4spd that’s geared too high. If you put the new 5 speed on the 3.8 it would feel just like the 3.6.
5.38 gears with the 4spd is same final drive as 4.10 gears with the 5spd. Has nothing to do with the motor.
This is incorrect.
The JK Dana 44 has one carrier for 3.21 to 5.38 gears. You don't have to change the carriers no matter what gears you started with or go to.
This is correct.
Good information.
Also good advice. In addition, there are differences between the Rubicon and non-Rubicon rear Dana 44 in the JK. The gears are the same, but the carriers and bearings are not and you can't swap between the two. Also, the axle shafts are different as well.
1 - 14 of 14 Posts
