Got manual windows but do not like the position of the handle? Then re-index it.
I just picked up my new '15 JK last night. I already noticed the position of the window handle did not quite work for me. My knee cap resting against door hit right on the knob end of the handle. Rather uncomfortable. Thought I would try to spin it around a little bit.
I have had this tool in the toolbox for years. It is used to remove the window handle clip. You could easily use a very small screwdriver or pick.
Still life photography
Step 1, Remove Handle
Position the tool behind the handle to grab the ears of the clip. Give a firm pull to remove the clip and the handle will slide right off.
Vehicle door Car Vehicle Gear shift Family car
Finger Hand Technology Electronic device Gadget
Step 2. Install handle
Once all the pieces are off, you should have these parts:
Re-install the clip on the backside of handle.
Hand Technology Finger Auto part Vehicle
The tip of the spline on the window regulator is tapered. That means you can install the clip before installing the handle. Place the large plastic trim ring over the handle hub. Line up the handle on the splined shaft and give it a firm push. You should hear an audible click when it seats.
continued....
I'm getting half doors so for me this will not be an issue, but I did test drive one with crank windows and I also noticed how the window crank knob sticks out right where your knee is. Seems like something that could have been engineered a lot better...something as simple as changing the rotational position like you have done, or maybe even moving it up a few inches on the door panel so it doesn't strike the average driver directly on the knee.
I just have to wonder if any of the engineers actually sat in a jeep before they finalized the design
I had pretty much decided I wanted the half doors already, but that annoying knob just reinforced my decision.
If you have your handle back past the top sometimes the weight of the handle will open the window slightly. I always put mine facing down. That might be why they put it where they do. It seems to be fairly universal to put it where the human knee goes no matter the company.
Nice write up I am sure it will help others with this problem.
