Personally, I would add oil 1 cup at a time until both sides of the dipstick reflect full. I am a firm believer of a little too much oil is much better than not enough oil.
If that does not work for you, measure the amount of oil you put into the crankcase and keep within the capacity limits reflected in your owners manual.
Second point is it sounds as if you might have too much blow by and might need a new set of piston rings!
