WOW. Interesting read. Talk about going down the rabbit hole. My JEEP 2015 JKU-R Hard Rock is a toy, not a daily driver. If it rolls out, we are likely going out to play, or heading out for an extended expedition to some location where we'll make camp and then go out exploring daily. We retired fairly well-off, so the only thing holding us down is two retired Great Danes (former show dogs). If we can convince the daughter to house-sit, we are going somewhere.
Going by the manual (something I do a lot) for my JEEP, it seems clear enough.
Check level 5 minutes after a warmed-up engine had been shut off.
After an oil change:
Since I do my own oil changes on the JKU-R Hard Rock, I'll drive it some to get everything up to operating temperature, then park it in the LEVEL portion of the driveway. I'll remove the drain plug and allow the old oil to drain. While it is draining, I'll pull the oil filter and replace it with a stock JEEP (MOPAR) filter, taking care to lube the O-ring and not over-torque the filter cap. While the oil drains I'll quickly check the front and rear differentials for proper levels, check the transfer case for proper level, and check all suspension bolts (marked with a paint stripe) to ensure none are loose or mis-aligned. By this time the oil pan is just a drip every second or so. I put the drain plug back in and torque it to spec. I fill in 6 quarts of my choice of oil. After filling I will always check the dip-stick and it always reads over-full. This is expected, but I just feel better seeing the oil level on the dip-stick before starting. The motor is mostly still warm since parking it, but the oil is not. So I'll let the motor idle while I clean up the tools, then shut it off and let it sit while I put away the tools. That takes about 5-minutes. I'll pull the dipstick and clean it, then check the oil level. It is always right at the full mark. I've never cared if it looked like a slight amount above or below the full mark.
We are at 65,000 miles now (just did an oil change after our Big Bend trip). At 50,000 miles I needed to replace the thermostat. While in there working, I also decided to replace the spark plugs. Probably unnecessary, but I did it anyway. As you know, you need to open the intake manifold to get to 3 of the spark plugs. The inside of the manifold was clean. NO OIL POOLS.
I'll never laugh at folks who IMHO over-maintain. I lean that way myself..... But this thread - WOW! Still, it made me realize that maybe I want to check my PCV. Something else for me to over-maintain? YUP !!!
