I am installing led rear aux lights on my JK. I wish to have them come on when I put the vehicle in reverse and also turn them on manually with a switch. I did a similar hook up years ago when I had an F250 and relay schematic I used for the wiring. Does anyone have a schematic using a 4 or 5 way relay for this specific setup? I believe I also had to use a diode in the previous set up.
Any help would be appreciated.
Not a schematic but a basic wiring diagram is below. I used the Carling switch but you can just ignore the 6 & 8 terminals if you are using a Daystar type switch. Also, I used the M17 for power to one of the switch lights (not M13). I forgot to go back and correct my mistake in the diagram.
No diode is necessary in this set-up. Hope this helps ....
