Was under the jeep today, noticed where the driveshaft goes into the axle, the seal is leaking. How hard is that to change. Does it require pulling the axles?
Just ran into this today after starting a routine brake pad replacement. Through a lot of trial and error I've found that the axle is easy to remove but the bearing and bearing retaining ring are quite a job to remove so you can get the seal off. Then you have to get a new bearing and retaining ring pressed on the axle.
What I learned:
*Don't start the job on a holiday weekend.
*You do not need to remove the rear diff cover but use a floor jack to raise the axle end you are working on to prevent fluid from pouring out.
*get all the parts before you start (retainer, bearing and seal)
I'll add for anyone who doesn't know, Permatex makes a gear oil RTV that works fantastic in applications where gear oil is involved. I plan to get lube locker permanent gaskets for my diff covers, but I figured I'd mention it in case folks didn't know.
