Just replaced rear brake pads on JK with 50k miles. Have driven a few days and is getting hot on passenger side. I pulled caliper, slider pins are clean, greased and moving freely. Any other areas I should check? The old pads on that side were worn slightly more than driver side BTW.
Think it's new caliper time?
also check to see if the e brake pads are dragging
if your replacing the caliper , replace the hose
